Question GTX 1660 high temperature when running Witcher 3 on maximum settings.
Aug 17, 2019
6
My Gpu goes from 77c to 87-90c after about 10 minutes of play time. Is this normal and is there anything i need to watch out for?
Aug 17, 2019
6
What is your ambient temp?
Is vsync enabled?
I'd try to keep that GPU under 83C to avoid thermal throttling.
Its about 27c outside and maybe 29c inside, i notice it always stay at 60fps because thats the maximum fps witcher 3 setting allow and vsync is on. Even rightt now when im browsing and have steam and discord open ot stay at 54c with 100% fanspeed going.
WildCard999
Herald
So yea, 29C is pretty warm. If the system is messy then you may want to clean up some of the cables to improve airflow or at the very least run the system (while gaming) with the side cover off. This would improve temps but you would need to clean it out more often as there would be more dust buildup.
6
This system is brand new so i dont think dust is the problem. My case is the 1stplayer x2 so its pretty concealed (cant find another word to describe it)
Aug 12, 2019
66
8
45
I have the same GPU, specifically the MSI Gaming X. It does get pretty warm, but it's also because i overclock the CPU And it gets pretty hot in the case, plus it's summer and my case doesn't really have that much airflow. I would recommend you check both temperatures at the same time both of your GPU and CPU.
Aug 17, 2019
6
my cpu stay at 61c and im not overclocking anything
WildCard999
Herald
ok so i have config the custom fan curve and take the front cover off. When im in the game it goes as high as 87c but as soon as i open the map by pressing M the temperature quickly drop to 67c. Is this normal?
It's probably dropping when you open the map due to it being much less graphically intense. 87C is still too high. Is vsync enabled in the options menu?
