Question GTX 1660 with low FPS
May 18, 2022
Hi, I have a GTX 1660 and a ryzen 3 2200g, and the FPS is really low, I play csgo at 1280 x 960 on low settins, the FPS gets around 95-130 sometimes 65. which is not good for the specs. on youtube the same pc gets 200-260 fps. I also tried hellblade on 1080p at medium and the FPS goes to 25 sometimes.
I know that my cpu is not very good, but the fps should be much higher than it is. I already formatted the pc, installed the latest drivers and its the same.
I'm about to buy a R5 3600, but I'm afraid that the cpu is not the real problem and the fps continue low.
PC Specs
- asrock a320m-hd
- RAM: 2x8gb at 2666mhz (one is ballistix and the other one is hyperx, I know mixing 2 different brands is not good but thats probably not the problem. it is in dual channel)
- CPU: ryzen 3 2200g
- GPU: GTX 1660 6gb
- 2x SSD Kingston 240gb
- Power source 500W 80 plus
