GTX 260 Sli Minimum Amps
Hmmm interesting, well i have 40 amps across 2 +12 rails, but i only have 2 6-pin PCI-e connectors. Would i just use the 4-pin to 6-pin adapters for the additional slots? Would i have to underclock the cards or something?
I just used the adapter. No you dont have to underclock the cards. What psu do you have? My psu is cutting it close but it works great because of the quality.
CPU: E8400 Core 2 Duo OC'ed @ 3.825 GHz
CPU Cooler: ZEROtherm / Butterfly BTF90
GPU: Evga GTX 260 core216
RAM: 4GB Cosair TWINX DDR2 800ghz
HD: Seagate Barracuda 7200.12 500GB Hard Drive
DVD+RW: Ermm I jacked it from an HP I had so im not sure =P
MOBO: Asus P5N-D Motherboard
well im runing two gtx260 with my antec trio 550w .. this psu has 3 lines each 12v/18amp, total 42amp
ok i have a 600w psu and if i were to get SLI with gtx 260 i would be fine because i have been told different
