GTX 260 Stuttering/Frame drop when playing games PLZ HELP!!!
Hussein Mansour
14
Hello, I have built a computer before and chosen to upgrade the graphics card to which I did because I wanted a smoother gameplay on my simple games ( LoL and CSGO ) they are not really graphics demanding and I thought a GTX 260 would do the job. I have gotten the GTX 260 from Gainward its the Golden Sample edition and I load up a game and every 2 minutes I get frame drop to about 1/3 fps and there is a lot of stuttering and I can't take it. Please help me I can't tell if its my drivers or my system is being bottlenecked as I never really faced these problems with my old 8400GS. My Nvidia Driver is updated to 341.81. Thank you for your help
My system:
Custom Case
AMD Athlon 64 X2 Dual Core @ 2.51GHz
160GB and 60GB HDD
Gainward GTX 260 Golden Sample
Brand New EVGA 500W 80+ PSU
DVD drive
Also can you recommend drivers as I did not receive a driver disk. So if you know what drivers came on the CD please let me know and I will try them out
I have 4GB DDR2 RAM my HDD used to work fine with my old 8400GS. Also I will give screenshot as soon as possible but the lagg drop and stutter only happens like every 1/2 mins although it is still very very annoying
that happens for atleast 30 seconds to 1 min straight or more
The VRAM should be running at full speed anyway, the only reason the Core would downclock is if it didn't think it was under load, that's why I suggest a display driver clean and reinstall. I know people who are running similar PC's for CS:GO and it works fine.
This is true yes, but the core clock shouldn't be that low, it might stutter a bit if it's using pagefile but with 1fps, I'd say the card isn't running at a speed it should be, something is limiting it.
Could you recommend some overclocking speeds that I could use in EVGA Precision X16. I think it goes higher than those speeds but thats when the lagg is not happening Ill try get another screen shot of when it is not lagging
That's more normal, for some reason it's throttling, try setting "Prefer Maximum Performance" in the NVIDIA Control Panel.
I have changed it to Prefer Maximum Performance for power settings. Anything else I should be trying. I haven't tested yet but i will get back to it as soon as possible
your cpu is what is causing your issues most likely, do you monitor it's temps?
you can also try to overclock it, though upgrading it would most likely be needed
Probobly caused by vram. If his vram is full then his clocks dont need to go up cause he doesnt have enough vram. And when i tryed to play a game on 4gb vram settings (i have 2) fps drops to 1 or more are normal. What happens if you lower the settings very much and the resolution on unheavy games like cs go?
Doing a clean install of graphics drivers may help.
I have done clean installs multiple times but I always choose custom and I only download the display driver and Physx driver. Can you recommend a stable driver. Also I overclocked my cpu by 7% and its now @ 2.67ghz . Not much change, I just dont understand what the problem is. I dont think it is the graphics card. Also when it is running stable and not lagging it gets up to 70 degrees, is that classed as overheating?
I don't know what to do. I can try overclock my gpu but I don't know what too. Also I was thinking about getting an AMD Phenom ii x3, would that make any changes?
Any help is greatly appreciated thank you
It seems to run stable at this rate. But isn't it still classed as overheating as it is right now?
This is when I was just browsing the web and using skype and spotify.
Yeah that's far too hot for just that stuff, gaming is probably downthrottling the clock rate.
What do you suggest i do?
This image is when I reduced the overclock to just 5%. It now runs at 2.6ghz but it still seems quite hot
I have noticed that the inside of the case is very dusty so I will be getting to cleaning very soon. I should get some new thermal paste and hope to get another cooler. Anything else I could try?
