Hello everyone,
My graphic card is way too hot - around 65 to 70° Celsius when used.
It is a nVidia GeForce GTX 260² from Zotac, bought somewhat two years ago. I cleaned the fan a few minutes ago: Unfortunately, I was unable to open the case, so I used a small brush and a q-tip to get all the dust out of it. That didn't help.
Someone told me to use SpeedFan to check the temperature, and the results were:
- GPU: 66°
- Temp1: 40°
- Temp2: 52°
- Temp3: 81°
- HD0: 33°
- Core: 56°
There are several ways to cool my PC case which I don't use atm because I don't know how to properly install new fans, or which ones to buy. The case is opened at the moment. Just in case you'd like to give me further advice, I'm gonna tell ya' what I've got:
- two fan slots in the back
- one slot on top
- one slot at the side
(- power supply supports a big, noiceless fan facing downward)
I'd appreciate your help ;-)
Thanks a lot,
Achim
- GPU: 66°
- Temp1: 40°
- Temp2: 52°
- Temp3: 81°
- HD0: 33°
- Core: 56°
- one slot on top
Thanks a lot,
Achim
