GTX 560 Ti (HELP)
lamela
Hi! I have a GTX 560 Ti with AMD phenom ii X4 955 and I can run watch dogs on lowest settings and it still lags! I just changed from a GTX 460 to GTX 560 Ti and its supposed to run better, but performance got worse. I don't know why but I really need help!
If you...
Yup! but performance in other games is not very good.. I'm only able to run battlefield 3 with a bit of lag on lowest settings. I have installed the latest drivers and I tried reformatting my PC, but still the same. This is strange.. I checked my video card benchmark and its supposed to run all these games smoothly! 🙁
Specs:
Windows 7 64-bit
AMD Phenom II X4 955
NVIDIA GeForce GTX 560 Ti
4GB RAM
If you have benchmarked your card then are the results typical of a 560ti ??.Moreover from when have you been experiencing performance issues.Also install all the critical windows updates.Maybe some program is interfering in the running.Try this if all else doesn't work
-Do a clean install of windows and install only the basic most essential drivers and nothing else.
-Benchmark your graphics card and see if its working all right.
-If it works fine then be very careful on what you install next because supposedly it could be some software which is causing problems.
