GTX 560 TI help
sunnyy
5
hi
So im thinking of buying a gtx 560 ti b/c im now using a ati hd 4200 lol yea..anyway im looking at some at newegg and wann know what ya think its a better buy and i will be sli them later.budget is $260 CAN'T go over that b/c im also upgrading all the parts on my pc.thx for any help
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133380 $229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125363 $234.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651 $239.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261101 $239.99
Can't go wrong really with any of these, they are all quality parts. Check things like the warranty, extras in the package, etc. I have an EVGA 560ti that has been working perfectly for 6 months.
I would go for the gigabyte card. Their windforce coolers are always excellent and it has the same adapters as the EVGA and PNY cards.
The only downside is it has a 3 year warranty compared to a lifetime warranty, but I know I upgrade once every couple years anyways so it makes it a moot point.
