Hi
I bought two Palit 2GB GTX 560 Ti's a few days ago, and have been running them in SLI. Nvidia surround is great, 6110x1080 =
Problem is, since they're so close together on my motherboard (ASUS P6T), the top card is getting no airflow at all, hitting 95°C+ playing games:
Not cool. (literally)
My first idea, obviously, was to move the card down a slot, creating a much larger gap in between the cards, like so:
Problem is, every time I've tried that, my computer hasn't booted, or has booted without video. Now I'm not sure if this is because my motherboard simply won't allow me to run cards in SLI in those specific slots, or if my PSU is somehow not powerful enough, or if the cards are somehow faulty.
Last time I tried moving the cards around it took me over an hour to try to boot properly, after switching the cards from slot to slot and rearranging the power connectors, unplugging / plugging in my computer, it finally started up properly.
Thing is, when it DID start up, my BIOS settings had been completely reset, my date was set to the year 2099, and my RAID 0 configuration had been lost. Reinstalling steam / couple hundred GB of games = double not cool.
So, I have a couple questions for y'all:
Is it possible for me to run the cards in SLI (perhaps get a longer SLI connector first) how I suggested, with one card moved a slot down, or is there some restriction with my motherboard that I'm not aware of?
Is it my power supply, my mobo, or the cards themselves that caused my BIOS settings to be completely reset / my computer not boot? Or is it some other problem?
Full list of my specs here, in case they're needed:
PC Power & Cooling 750W PSU
2x 2GB Palit GTX 560 Ti's [SLI]
3x WD 1TB Caviar Green [RAID0]
WD 1TB Caviar Black
Intel Corei7 920, not OC'd or anything
6GB Corsair XMS3 DDR3 Triple Channel RAM
Lexa Blackline case, all fans replaced with 120mm 1900RPM Scythe "Slip Stream Kaze-Jyuni" fans.
WD 1TB Caviar Black
