GTX 560Ti SLI with a 700W psu? (cable problem)
Princeps
So I just got a second GTX 560 and I am planning to SLI it. I have a 700W PSU (http://bulk.fsp-europe.com/pdf/datasheets_psu/fsp700-80bpn_85.pdf) which should have enough power but it doesn't have enough 6pin connectors (it has 2X 6+2), I need 4.
I have also 3 fans and the PC is custom-built but not by me and I am not super confident with the cables. The fans run through a control switch (integrated within the case) which controls the speed of the fans and allows to turn them off.
There are a lot of molex adaptors connected to eachother for the fans.
By any magic is there a way to get power for the second GPU?
Got my cables, installed the card, connected with the SLI bridge to discover my motherboard doesn't support SLI. I have a "Asus P8P67 LE" motherboard.
Would using software like HyperSLI solve my problem? "http://www.techpowerup.com/forums/threads/hypersli-enabling-sli-on-non-sli-motherboards.153046/"
Also I'm having difficulties understanding which expansions slots I should use. Screenshot of the PDF manual: http://puu.sh/lGCcG/a19a096347.png
You will have to try HyperSLI for yourself. There's no guarantee that it will work.
These are the only two slots that the two graphics cards will fit into:
