GTX 650 Ti BIOS Problem
HSBATTH
43
Hi Guyz,
I have a GTX 650 Ti 1gb GDDR5 however,my PC detects it as GTX 650.I have purchased it as a used card,so I do not have the bill.Hence I can't replace it either
Ques) Will my GTX 650 Ti work as GTX 650 Ti or GTX 650 if I don't resolve error with BIOS?Is it gonna make an impact on gaming? From now will my card work as gtx 650 or gtx 650 ti?
use gpu-z to read the card bios info and print it out. then look at the card and see if the card part number matches up with the 650 or 650ti if the part numbers dont match right or the bios does not line up. if you got the card on ebay then file a claim with ebay as part not recived as the right one.
