GTX 650 TI low FPS ?
sam1911
203
I have the Asus GTX 650 TI and getting low FPS on games like assassins creed 3 , NFS run , mostwanted 2012
my system : core 2 duo E4300 @1.8 GHZ
ram 2 GB DDR2
GPU GTX 650 TI DDR5
PSU Cooler master 600watt
FPS are like
Assassins creed 3 : before Boston 60+ FPS & inside boston :10-15 FPS 🙁
NFS RUN : 30 FPS on cinematic ,on road 18-28 FPS 🙁
mostwanted 2012 : very fast starting 50 FPS after some time 15-20 FPS 🙁
DMC 5 : 38-70 FPS and sometimes 90 FPS on ultra !!
I am really confused !
any help wud be appreciated! :)
Mess around with settings, particularly ones that will use CPU performance rather than GPU.
Try your hand at overclocking, just dont expect too much of a difference.
Trim down on the software running in the background, anti-virus software oftens runs on startup and can be somewhat of a hog on performance.
You could overclock the CPU, but that wouldn't solve the issue, just alleviate it a bit. Though I wouldn't try, older CPU's are limited when it comes to overclocking as well as a lot more complex as you have to balance the RAM as well.
Seems you just have to grit your teeth until you can afford a platform upgrade.
Lower some settings that are more CPU biased. Tweak with the settings until you find something that's playable.
thanks and will have to do that until I get to upgrade :)
can I get any i7 ? coz my friends are already using i5 & i just dont want to go with that 2 core 😛 or I ll have to wait ! BTW thanks for the suggestions
i7s are £200+ for the base models. i3s have hyper threading which gives 4 cores and to be honest few games use more than 2 anyway.
i7 is more for video editing/rendering, i5s are for high end gaming and i3s are for normal gaming and general interneting/word editing etc
