L Lucisnox Reputable Sep 11, 2014 22 0 4,510 Jun 5, 2015 #1 hey guys. just want to ask if the gtx 660 reference card run on my current set up? CPU : g3258 MoBo : gigabyte b85m-d3h HDD : WD 500gb caviar blue Ram : 2x4gb ripjaws x PSU : zalman 400-le 400w no ODD and other peripherals.
QSV Honorable Feb 26, 2015 517 0 11,060 Jun 5, 2015 #2 Will be plenty. I have a similar setup with a much more powerhungry overclocked CPU and the 660 is also overclocked. It draws 355W max. when running Prime95 and Furmark at the same time. 12V rail is strong enough too. Upvote 0 Downvote
smorizio Titan Jan 22, 2010 30,980 11 125,315 Jun 5, 2015 #3 no i would not try it. the 12v line at 400w will be to low to run the cpu and gpu without shutting down or failing. Upvote 0 Downvote
L Lucisnox Reputable Sep 11, 2014 22 0 4,510 Jun 5, 2015 #4 the zalman has 2 12v rail @ 12.6v each. so does it mean 25.2v? im not good with the voltages in a psu. XD Upvote 0 Downvote
L Lucisnox Reputable Sep 11, 2014 22 0 4,510 Jun 5, 2015 #5 and it also has a 6pin pcie connector Upvote 0 Downvote
L Lucisnox Reputable Sep 11, 2014 22 0 4,510 Jun 5, 2015 #6 which one should be better? ASUS GeForce GTX660 DirectCU II OC edition GTX 660 or the oem reference card? Upvote 0 Downvote
