I know it's been a while, and that this thread has been "resolved", but my solution could help someone else.
I have a GTX 660 hooked to 3 LCD monitors on Win7 ultimate 64. This setup have been performing flawlessly for over 2 years now.
Unexpectedly, 2 days ago, for reason I still can't understand, the GFX card stop downclocking to idle speed (324Mhz GPU, 162Mhz RAM), but stayed at P2 P-State (862Mhz GPU, 1500Mhz RAM) after quiting a 3D application or game. It would boost and turbo boost to max clock, no problem, but never went down all the way back to 2D idle clock.
I tried everything in the book, including system restore 10 days earlier, uninstalling a bunch of stuff and using DDU to uninstall the video driver in safe mode. Still the same issue. I was about to consider either my card had an hardware issue, on windows/the registry was borked and need a fresh install.
Then, out of desperation, I went back to the GPU driver control panel and looked at all the options and settings 1 by 1. I then remembered reading this thread sooner today where it was mentioned multiple times "I have only 1 monitor" and thought "maybe my problem has to do with my 3 LCD setup." I disabled 2 of the 3 monitors with GPU-Z opened for monitoring and immediately, the clock went down! Amazing! I then re-enabled the 2 monitors, fired up to a game and immediately after quiting the game, the clock went down to Idle speed as it should, with all 3 LCD enabled.
Problem fixed and I wound NEVER have guessed... Hope this helps someone someday!
