E eminem619 Honorable Dec 21, 2013 274 0 10,790 May 9, 2014 #1 i have a 13000inr budget the best i can find is gtx 660 zotac....2gb...is it good????for 1080p???ll play games like crysis 3....far cry3.....
Solution I I i7Baby May 9, 2014 The gtx 660 is a good card. http://www.tomshardware.com/reviews/geforce-gtx-660-geforce-gtx-650-benchmark,3297-8.html You should get about 40 fps in Ultra 1080p
jessterman21 Splendid Dec 14, 2010 2,928 2 21,465 May 9, 2014 #2 Yep - 30-40fps on the highest settings, and 45-50fps on High. Go easy on the antialiasing in those games - performance killer. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 May 9, 2014 Solution #3 The gtx 660 is a good card. http://www.tomshardware.com/reviews/geforce-gtx-660-geforce-gtx-650-benchmark,3297-8.html You should get about 40 fps in Ultra 1080p Upvote 0 Downvote Solution
logainofhades Titan Moderator Apr 27, 2009 40,092 5,254 148,290 May 9, 2014 #4 Looking at prices to comparable cards, that is a good deal and is a good card. Upvote 0 Downvote
