Hi,
I have problem with my new graphic card and don't know if it is driver issue or if it is defective graphic card or some other component is bottleneck ? Can you please help me?
My PC
CPU: AMD Phenom II 1090T 3,2 GHz (is bottleneck?)
MB: ASUS M4N68T updated BIOS few days
GPU: MSI N670GTX-PM2D2GD5/OC installed 301.42 WHQL drivers and also tried older drivers from CD
PSU: Corsair TX650-V2 (is it enough? )
Case: Coolermaster CM690 Dominator II
RAM: Kingston DDR3 HyperX 1600MHz 2x2GB +2x4GB
Monitor: LG W2242SM connected by VGA adapter (playing on 1680x1050)
My problem is:
In games like battlefield 2, Crysis 2, ArmaII, Alice Madness Returns, Dragon age, Skyrim my fps drops very often.
For example in Battlefield 3 (Gulf of Oman) I start game with 80fps (setting: ULTRA 1680x1050) and after 2 minutes fps drop to about 30-20 or even 17 fps. I first thought it was only big scene with many details but when i stayed in same place about 1 minute it returned to 75fps but scene was still same.
I tried:
- Change details to High - even worse , Medium and Low - still remain,
- Turn off- blur, v-sync - problem still remains
- turn off anti aliasing - Problem remains
- in nvidia control panel turn v-sync off and power management set to maximum performence, in windows too
- re install drivers - clean installation ( i try all drivers available from MSI site and Nvidia too
- Re install windows (windows 7 professional 64-bit)
- uninstall MSI afterburner, than install newer one.
I took screenshot from MSI afterburner where you can see huge GPU usage drop in game.
Thank you for any help
My PC
My problem is:
I tried:
In the end of FPS graph you can see long stable low fps and then shorter stable high fps. In that time I did not move in the game. It means it was same scene all the time.
