So, recently I did a fresh install of the new WHQL drivers (previously was at 310.70), but now I'm experiencing a lot more crashes than normal. For instance, I'll be browsing the internet, and bam, driver crash. Most of these require a reboot if I don't get the "Driver Crashed" popup. Another instance, while playing Far Cry 3, my GPU usage will plummet to 0%, causing a momentary freeze, and do that 3 or 4 times, then lock up, sometimes with audio repeating as well. Is this just a sign of a bad driver, because up until now my newly SLI'd setup hasn't given me trouble. No overclocks on cards, CPU is OC'd to 4.4 (i5 3570k). Thanks for any advice.
Also, the only things that have changed have been those drivers, and putting new thermal paste on my CPU and Hyper 212+ cooler, and moving to the most recent BIOS for my motherboard.
I find this in my event viewer:
" Display driver nvlddmkm stopped responding and has successfully recovered".
This is followed by this: "The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event:
\Device\Video7009e(1cd4) 8400000c 744100f8"
Basically, I've tried everything. Reseating RAM, cards, checking RAM settings/Memtest, disabled audio drivers, etc. Crashes seem random, stable for hours, then another error. Anyone have any advice? Further research shows most suffer from this TDR error, and point to multiple causes. I'm just really hoping it isn't hardware related, I've already spent enough money building this computer. Maybe adding my second card did my system in? Or maybe it's faulty, but it ran perfect for almost 3 weeks, so a sudden failure seems strange when both work as entended when this error isn't occurring. Thanks for any help, I need it.
System: i5 3570k (4.4 OC)
Asrock Z77 Extreme4 Motherboard
Corsair HX750 PSU
16gb Corsair RAM
2x EVGA GTX 670 SC 4gb SLI
Corsair HX750 PSU
16gb Corsair RAM
