GTX 670 Way too hot idle and load
Flaza54
Commendable
Mar 17, 2016
My GTX 670 (a few years old at this point) has been running VERY hot recently and I'm not sure why.
I tried playing Black Desert Online last night and within seconds of entering the character customization (especially the face customization), my GPU was hitting 90C+ and the fans went nuts. I noticed this, closed the game and waited for the GPU to cool down, it bottomed out at around 75C.
I knew this was still way too hot for an idle GPU so I called it a day and shut the PC down. 7 hours later I booted the PC up again, checked the temps and the GPU was sitting at 74C shortly after startup.
For reference, my CPU (i5 3570k) was sitting at about an average of 55C when the game was running and idles between 35-45C across the different cores.
I'm pretty sure this isn't an airflow issue, as I've never had these problems before and all my other temps seem fine. I cleaned out my PC fairly recently and double checked it last night, there is little to no dust to be found.
Is is just time to get a new GPU?
It sounds like the thermal paste needs replacing. Once it gets past a certain age, and after a lot of usage, the thermal paste will begin to break down, meaning that heat is not dissipated as efficiently. If your card is out of warranty (going to assume it is) then simply strip the card apart, clean off the old thermal paste, and replace it with some new stuff. Which make and model 670 do you have?
That should not be the case (to get a new gpu)
I would recommend you clean the graphics card from dust and apply new thermal on it . Also MSI Afterburner is very helpful at providing temps , custom fan speeds , and overclocks . Make sure all over clocks are off
The thermal paste never even came to mind, but that definitely makes the most sense, thanks.
It's the Palit Nvidia GeForce GTX 670 card.
The Palit 670 uses a pretty cheap thermal paste, and after 2 years it should have been replaced. But it's a fairly simple procedure, so you shouldn't have any problems, and you should see a decent temperature drop as well. Depending on which version of the GTX 670 it is, you can even replace the cooler with a GTX 760 Jetstream version and get better temps.
I did something similar with my old Inno3D 670 (it uses the NVIDIA reference PCB which made it easy):
http://imgur.com/a/loTYS
