[SOLVED] GTX 750 Ti Dual Fan OC without using the 6 pin connector for normal use
Dec 26, 2019
126
4
95
I am currently looking for a GTX 750 Ti Dual Fan version but all of them are OC version and has 6 pin ports. Can I use the graphics card in normal use without plugging the 6 pin connector? I'll never overclock the thing.
WildCard999
You initially stated you weren't going to overclock it in the first post.
Since it's a even trade could you get a decent PSU with a 6-pin connection? I'm highly against PSU adapters and while it may work on a low power GPU it's still something I wouldn't recommend as I've seen a few threads over the years about adapters melting during high load. Even a Corsair CX 450 grey label would work well and is pretty inexpensive depending on where your live.
Reactions: DeAdLyWaRrIoR07
RealBeast
I think that the simple and safest answer is that if it has a power port -- use it, although it's your card so if you want to try it that would be up to you.
Dec 26, 2019
126
4
95
I think that the simple and best answer is that if it has a power port -- use it.
I'm sure that I will need a new PSU for that, I have an OEM PSU that doesn't have a 6 pin connector. I only need a graphics card not "a graphics card and a power supply with 6 pin connector".
I already have a single fan 750 Ti, but this thing is loud. Hoping for Dual Fan to do the same job without creating such noise.
RealBeast
Does your PSU have any unused Molex connectors? Since you are not going to overclock it, I would consider something that I usually don't -- using an adapter Molex to 6 pin. And what is the wattage on your PSU?
Dec 26, 2019
126
4
95
The 750 ti usually runs fairly cool, what about making a less aggressive fan curve via MSI Afterburner so it's quieter? I'd try this before buying the same GPU with two fans.
I can straight swap my Zotac GTX 750 Ti to the guy's Zotac GTX 750 Ti Dual Fan version without adding cash (both are 2GB 128 Bit). That's why I'm asking.
WildCard999
Dec 26, 2019
126
4
95
Yeah I mistaken that, my PC is freaking out rn.
Well I am going to get a CX 450 for 20 bucks which is a good deal, but I need to add more RAM and HDD first.
I guess I'll just buy the PSU first.
