GTX 750 Ti Power consumption
Amirul Naim
17
I am currently using a Radeon HD 7750 GPU and thinking about upgrading it to a GTX 750 Ti
What concerns me is the power consumption. Will it be a better to handle the new graphic card?
On my PSU, under the Voltage section shows +12v1 and under it shows 15A
under the Current section show +12V2 and under it shows 16A
I dont have any problem running the 7750 but im worried about running the 750 ti
Is it ok?
EDIT: A picture of the PSU im currently using http://puu.sh/egEJZ/da4d50712f.jpg
Yes, like I said before the gtx 750 ti uses less power than the 7750 so it has to be able to handle it.
Just make sure you get the mainstream/lower end 750 tis, the higher end ones come with exotic coolers that require extra power.
It's a stock PSU that comes with the casing and i have been using it for 1 1/2 years. I am scared that the upgrade would damage the GPU since this is a low quality PSU. That is my concern.
But since it can run the 7750, i'm a bit scared about it running the gtx 750 ti.
You really think the Psu can handle the gtx 750?
Ty for your input but i think i will buy a corsair Vs450w along with the GPU to be on the safe side since this PSU came with the casing which only cost 25$ so you could kinda guess the quality of it.
Better be safe than sorry i guess xD.
