GTX 750 TI problems in Dell Inspiron 660
Allen_Tok
7
Hello guys,
Recently I bought a new GPU to upgrade my Dell Inspiron 660. The GTX 750 TI 2GB version that does not have a 6 pin connector. The PSU for the Dell PC is enough wattage. And when I tried to install the new GPU it wouldn't work, I would just be stuck in BIOS. I'm not sure what to do and help would be greatly appreciated!
If it's a prebuilt pc, are you sure that your mother board/manufacturer allows for the addition of any components other than those that came with the PC?
I'm not sure whether it's compatible or not, but I've seen many threads of people with Inspiron 660's with GTX 750 TI'S that work fine
The problem is the BIOS, my motherboard is not allowing it to work and I can't boot up the OS, windows 7 btw
