GTX 750Ti compatible with a slim (SFF) case?
JohnNada
I don't think you can fit even one fan version of it by evga but if you were just a little bit bigger it would fit just fine (http://www.amazon.com/dp/B00IDG3IDO/ref=psdc_284822_t3_B00IGQ4UX8) :)
sorry.. :/
if you are not gonna do very serious gaming you can try amd's A10 APU, it is a cpu and gpu in one, in terms of cpu its almost as good as a fx-6300 and it can run bf4 at 1080p at med to low settings at more than 35 fps:
other benchmarks(at differents resolution):
all for 150$
so it would be perfect for 720p :) but I would get a bigger case if I were you...
sorry.. :/
all for 150$
According to this tech sheet from the HP website, NO: http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=5037931&docId=emr_na-c02778024&docLocale=en_US once the PDF has downloaded, click the 'features' tab on the left side then scroll down, the system has a PCI-Ex16 slot but it's limited to 25Watts, to all practical intents and purposes useless for a graphics card-the built in graphics will almost certainly be as good, if not better than those that a 25 Watt dedicated card can provide.
