GTX 750ti not giving display on lg monitor
pushkar_1
Commendable
Jan 29, 2017
36
Hi,
I upgraded my PC with gigabyte H8M-S rev 1.0 and Intel G3240
But my graphic card GTX 750ti was not giving output to my LG FLATRON E2042.
So I took my PC to the local repair shop they plugged in and it worked only monitor was diff apart from that everything was mine.
Also I tried on my friends Samsung 32inc LCD it worked !
PC boots but from starting it has no display (black screen) usual msg of power saving mode comes up and then blank.
Please help me are there any settings for this type of monitors.
If your PC and graphics card both work okay with two different displays., there is nothing wrong with your PC or graphics card.
The problem is with your LG Flatron Monitor, maybe to do with the type of cable and the output port you're using on the graphics card?
For example, the LG Flatron E2042 only has a D-SUB analog input. If you try to feed a digital-only signal to it with an adapter, it won't work.
how do i find that, if i am giving digital or analog input.
yes i am using a DVI-I to vga convertor
what should i do ?
okay i will try it btw its not tv its a 20 inch LG monitor in which it shows no signal
adapter is working fine so the vga cable and monitor its just they are not working together.
it worked with a basic lcd monitor at repair shop but dosent work with my monitor
though i dont know about the input signal that might be the issue
PROBLEM SOLVED !
it was the faulty VGA cable pfft.
thanks for your help
