Gtx 760 compatible with a68hm-e33 v2 motherboard and a8-7650k cpu?
Jul 2, 2018
9
Hi, I have an a68hm-e33 v2 motherboard which came prebuilt with a a8-7650k cpu but I’m not sure if a gtx 760 will be compatible with both of these can someone please just clarify the compatibility for me?
I use a GTX 750 with a a8 5600k ... works as intended. GPUs will work on all Mobos with a PCIe slot.
Dont worry about your PSU if you have at least 350w you should be fine for that setup.
not with a gtx 760 no
need at least a decent 500w with the proper pcie cables
no
if it is old and you need to get adapters it is time for a new power supply
that or get a gtx 1050 ( a version that runs on the pcie slot alone)
which is better anyways
