GTX 760 fan curve settings. Am I damaging the fans?
TheSquirrel
Hello,
I've often come to the Tom's Hardware forums for assistance this is the first time I've asked a question myself.
I recently got a new gaming rig with a 3.2 i5 and a MSI GTX 760 2gb video card. Naturally I booted up Crysis 2 and maxed everything out to see how it will handle things. It hit the 80C mark pretty quick. From reading this is where the GPU booster cuts out. It's not a dangerous temp apparently but it's higher than I would like.
So I downloaded MSI Afterburner and set a fan curve and I'm keeping it around 69-70C during heavy action. This is with the fan spinning at 80-90%.
I was curious what the long term hardware effects are for running the fan at this speed. Am I extending the length of the card only to have the fans die out on me sooner? Or are the fans designed to handle this kind of load and speed and I don't have much to worry about?
http://imgur.com/1sLlG9S
This is my current profile. So it does slow down to about 40% when the GPU is not under load. Should I lower that to 30? It's the default minimum that Afterburner had in but when running with the default fan settings it lowers to about 30. I guess I could just close Afterburner when I'm not gaming that way it returns to the default 29%.
Any changes you think I should make to the curve profile? I don't have it overclocked in anyway except for the built in GPU Booster (I obviously don't know enough to overclock, I'm terrified I'll fry the card).
It's a matter of taste, really. If it doesn't bother you noise wise, leaving it at 40% below 30c is totally fine, if it does bother you, just set it 30%.
Otherwise the curve looks fine to me. 😀 http://postimg.org/image/se8dwb39d/
Cool. I altered it slightly to be more like yours. Going up 10% with each 10 Degrees of heat. We'll see if it can maintain the 69-70 temp while playing during that. If it doesn't I'll swap it back to the one I posted.
The sound doesn't really bother me, if I didn't know it was just the GPU fans I'd probably freak out but since I generally game with headphones the 80-90% sound doesn't bother me. Runs rather quiet at 40%
Thanks everyone for your response, and if anyone has any more information I'd be happy to hear it. Guess this is where I'll come when I finally get up the courage to overclock it some.
