How much watts does my PSU need to have to run a GTX 760 (OEM) 1.5GB? Nvidia website says it has a maximum consumption of 130W and recommends a 350W PSU, I have a 350W one with 23Amps on the 12V+ Rail and it has the required 6-Pin, also my PC components:
I3-2100 3.1Ghz
8GB DDR3 1333Mhz (2*4)
1*WD Blue 500GB
A CPU Fan and 1* Case Fan
No DVD-Writer
The system should draw at maximum 245W which is equivalent to 20.5Amps, I won't OC or add anything else as in the near future I would just change PSU, so what do you think?
Thanks!
I3-2100 3.1Ghz
1*WD Blue 500GB
No DVD-Writer
Thanks!
