I'm looking at buying an EVGA GeForce GTX 760 graphics card. At Newegg the power requirements are listed as "500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail." My power supply is 550 watts but I'm unsure whether the amperage is sufficient. Here are the specs:
• ATX12V V2.2
• Modular
• 80 PLUS Certified
• 100 - 240 V 47 - 63 Hz
• +3.3V@28A, +5V@26A, +12V1@22A, +12V2@22A, +12V3@25A, -12V@0.5A, +5VSB@2.5A
(It's this one... http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016)
I see each 12v line is less than 30 amps. Do these need to be over 30 to work with this card, or should I be ok without a new power supply? Any input is appreciated!
• ATX12V V2.2
• Modular
• 80 PLUS Certified
