GTX 770 asus power connectors
So you have four pcie 6+2 pin power connector.thats enough for a GTX 770 to work flawlessly but plug the right plug to the right port
are you sure its only 2 6 Pins? A lot of the time they come with 2 6+2 pins so they can be either 6 or 8 pins. What PSU do you have? You should be fine if you get a 6 to 8 pin adapter, but finding out the PSU model first and see if it can handle it should be first.
i have a coolermaster gx750w
