V Vapor145 Reputable Mar 17, 2014 1 0 4,510 Mar 17, 2014 #1 I have an EVGA GTX 770 card in my system which has one DVI-D port and one DVI-I port. Will this card support one monitor at 2560x1440 on the DVI-D (using an appropriate cable) and one 1920x1200 on the DVI-I port in a dual monitor set up?
Solution E E enemy1g Mar 17, 2014 Yes it should. You really only have to worry about inputs when you're looking at a triple monitor setp.
E enemy1g Honorable Oct 3, 2013 2,224 1 12,460 Mar 17, 2014 Solution #2 Yes it should. You really only have to worry about inputs when you're looking at a triple monitor setp. Upvote 0 Downvote Solution
deadmaufive Distinguished Feb 5, 2013 407 2 19,015 Mar 17, 2014 #3 You should be able to set them up separately under the windows display settings. Upvote 0 Downvote
