GTX 770 - Why can I only connect to my monitor through VGA?
marcom90
11
Hey everyone I recently had this computer built... it has a couple VGA / DVI ports as well as one HDMI port...But when I try to connect it to my ASUS monitor it only ever connects through the VGA, am I doing something wrong? This is my first build.. so sorry if this is a stupid question.. is there any program I have to configure on my computer?? Why does only one combination of ports work? I'm confused :S Appreciate all and any input! Thank you in advance!
Specs Below:
Link for the Monitor:
http://www.ncix.com/detail/asus-ve247h-23-6in-widescreen-led-b6-57310-1141.htm
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
Motherboard: ASRock Z87 Extreme4 ATX LGA1150 Motherboard
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Crucial M500 120GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 770 2GB Superclocked ACX Video Card
Case: Corsair 200R ATX Mid Tower Case
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)
Cooling: Cooler Master 212 EVO
If there is a graphics card installed, your motherboard will want to use that primarily, which may be why only VGA works if you are using the motherboard header (for diagnosing problems or something). When you use the motherboard connector you wont get the processing power of the GTX 770 you installed, so it would just more or less sit there.
Hey here is the monitor I have : ASUS VE247H 23.6IN Widescreen LED LCD 1920X1080 2MS 10M1DC HDMI DVI-D VGA Speakers.
It has one of each connection; one HDMI, one VGA and one DVI. But no matter what is plugged in when I hit source on the monitor only VGA works.
Thank you for the replies guys!
Just to clarify you are plugging the VGA cable into the graphics card (770), and not your motherboard (by the USB ports).
As far as I can tell there are NO GTX 770's with a VGA port.
Is this your card? http://www.amazon.com/EVGA-GeForce-SuperClocked-Graphics-02G-P4-2774-KR/dp/B00CZIQXBA
You have 2x DVI, one HDMI and one Displayport. No VGA. It does have a DVI to VGA adapter, which you would have to connect.
Make sure you are not plugging it into these:
http://wimages.vr-zone.net/2013/07/IMG_4667.jpg
Yep thats the card! And, ok I think I had it plugged into the ones near the USB, (I'm at work now so I'll double check when I'm home) and sorry I just assumed it did have VGA because when i hit source on the monitor it would just automatically go to VGA because that was the only one that worked.. I also tried putting in the HDMI also to no avail
Ok, once I get home from work (Going to be a few hours!) I'm going to make sure they are plugged into the graphics card and nothing else, if that doesn't work i'm going to check the BIOS and make sure to set it to peg / pci express graphics and I'll keep you posted on the results. Again thanks for the help guys, appreciate it!
