GTX 780 (maybe ti) for 1440p? MONITOR HELP ALSO NEEDED
ChizYT
93
Okay, so I want to be able to record BF4, and other demanding games. So, would a GTX 780 be enough or will I need to upgrade to the Ti edition? Please include the model of the 780 or 780 ti if possible 🙂
ALSO: I'm stuck on a monitor. I decided not to go 2 monitors. SO, what is a good monitor that has great color accuracy, yet can be used for gaming? I know any monitor could be used, but i'm looking for a more professional grade monitor at around a $500 price-point
Currently looking at: ASUS PB278Q
Well, I'd say GTX 780 ti, because in 1440p the GTX 780 won't get 60 FPS on Ultra, maybe 45 if you're lucky. So, for $200 more, I recommend you to get the MSI GTX 780 ti. With a slight OC you will get 60 FPS no problem.
Regarding the monitor Dell U2412M IPS Monitor be better than the ASUS PB278Q
& yes there is no reason to upgrade your gpu,it will work fine
Thanks! Just waiting for a little more opinions before I pick a Best Answer 🙂
EDIT: Unfortunately the Dell U2412M is unavailable in where I am purchasing my products ):
