Gtx 780, PC won't power up at all when video card connected to PSU
nickenix
5
Hi there,
My Galaxy gtx780 HOF card stopped working yesterday.
Basically the computer will not start at all if the card is connected to the PSU.When I disconnect the 780 from the PSU the PC loads up normal. What would that specific issue usually indicate? There is no visible damage/burnt parts on the PCB at all.
I tested the PSU and put another GPU in the mobo, and that worked fine.
I also tested the 780 on another mobo and another PSU and again the PC would not power up at all when the GPU was connected to the PSU.
Hoping the card is not totally fried and that it's an issue related to the power connector on the gpu's pcb.
The PSU is a Corsair 600W TX and it's been working fine with the GPU for the past 6 months.
The other GPU I tried was the gtx650.
The other PSU I tested it on was a 700W Apevia.
The Apevia is fecal, do NOT plug it in to such high-powered hardware, as you risk blowing it up, possibly killing attached parts.
As to the Corsair, while it is a decent model (not like the CX), it is possible that capacitor aging has reduced its capacity, or it could simply have a problem.
So I tested my gtx780 again, this time on a brand new 750W HX from Corsair and unfortunately it was the same result, when connected to the PSU the PC won't boot whatsoever. If I leave it in the PCIE slot and not connect it to the PSU the GPU's aesthetic lights work but device not recognized/seen by windows or bios.
So I am left with this question, What do you think, specifically, the problem with the gpu could be with the symptom of the PC not booting at all when GPU connected to PSU? Any chance in hell that it could be a relatively simple fix? Will a trip to the reflow oven maybe help?
My GTX 780 HOF also died after six months of multi-montior gaming. Go GalaxyTech!
I have a rosewill 1000w PSU with more than enough power and it seems to be working fine with my older HD 7850. Just like nickenix, my 780 HOF is not seen/recognized in the device manager. When I get home today, I will strip it apart and reflow it as a final resort. If I get no dice, I plan on purchasing a 6gb Superclocked. Good luck to you nick!
The reflow worked! But not for long =\ The card was alive for about 20 seconds. I was able to see my motherboard splash screen. A few seconds afterward, my monitor lost display signal. No dice on any other monitors. Im going to leave the card in my system for the next few days along side my 7850. If it doesnt magically appear, Ill give it another reflow.
Atleast we can now rule out a broken PSU!
