GTX 780 TI and IPISB-CH2 Bios Update problem..
Millgo47
77
I installed my GTX 780ti but when I just turn on my PC it just sits at the very first screen I cant even enter Bios... I have tried the update for Bios but it says "System BIOS image is invalid please download patch again" and I cant seem to get anywhere. Anyone have any other ideas?
What kind of processor do you have?
What kind of memory do you have?
Do you plan on getting a new case or using the existing one?
Please tell me that you got a new power supply when you purchased that graphics card. If not, that is most likely your problem.
As far as the BIOS goes you are going to have to try downloading it again and make sure that it is for the correct model. If you install the wrong BIOS you will brick your motherboard. They have a lot of steps to prevent users from installing the wrong BIOS. I wouldn't be surprised if you chose the wrong revision of your board.
I did buy a new power supply, Corsair CX750 which the card says 600W+ so that shouldn't be the problem.
I went to the HP site and downloaded the exact drivers it says directly on my Motherboard
They are the latest drivers but wont install for some reason. I'm guessing it might be Windows 8... If that's the case do I have to buy a new motherboard?
Yeah it had windows 7 on it... Do you know a decent motherboard I should buy then?
Yeah there is already a few wires I don't know where they go... Going to have to look alot up on my cell since I have no PC lol.
there's what seems to be a tiny bronze ground wire or something on my hp board but don't see it on my new board
