GTX 780 TI Power Supply
toyftw
Dignified
Yes, that PSU will support a system with one gtx 780ti. It is an entry level/budget series PSU, but has plenty of
power for a sys with that GPU.
Derza10
Dignified
Amwoodeim
24
Even with the supplementary 8 pin and 6 pin connector? I won't be around my PC for a month now, so I'm not able to check... I know the power supply will power it, but I'm wondering if the pins are available.
Derza10
Dignified
Yes it has the pins you need in-order to power a GTX 780 Ti. It will work just fine.
toyftw
Dignified
Hi again - Yes, the CX750 has 4 6/8 pin GPU connectors, actually 2 more than you require. You're good to go.
Enjoy - also, you have plenty of spare +12v amps should you decide to OC at some point.
Amwoodeim
24
Hey! Thank you so much. I've got training at Ft. Knox for a month starting tomorrow and now I know I have something to look forward to after it's done. Gonna be running BF4 easy!
Similar threads
