GTX 780TI help!!!
Karthick Babu
44
I've decided to buy gtx 780ti after a long surf.. But wanna know is there any performance difference between stock cooler and custom cooler... Asus and zotac are the only brands who provide 780ti in India with stock cooler only... Will the stock cooler will be quiet enough?? I will be gaming @ 1080p and may be use dual displays in future...
i7 4770k
asus z87 pro
gskill 8gb
corsair tx850
corsair 230t
wd 1tb
Karthick Babu
44
is there any performance difference between custom and stock cooler???
caj
Custom usually are d 3rd party proprietary designs offering better cooling or tweaks. Stock coolers are d default coolers at cards launch by nvidia.
leeb2013
also the stock cooler vents the hot air outside your case, but most custom coolers are more effective, but vent the hot air inside the case, except some like my avatar
St0rm_KILL3r
1,086
If I were you I would buy gtx 780ti from amazon.com. Even if you pay in dollars with an U.S bank account you will be saving 30-40% money. I think you should get the asus gtx 780 ti. And I don't think only zotac and asus provide gtx 780ti in India. You should check in other places like Lamington road if you live near mumbai, Grey market if you live near Kolkata and Nehru place if you live near delhi and more.
Ordering 780ti from a microcenter will be a lot cheaper than ordering online from websites like Flipkart.com
If you wan't to save lot of money and get similar performance, then I suggest you to get the Sapphire tri-x r9 290x which is easily available in India. Right now gtx 780ti is not worth the money in India.
Latest posts
