GTX 950 Problem
Jared0215
Im having trouble putting my new EVGA GTX 950 FTW in my mither board which is an ASROCK B85M-DGS. Ive applied pressure but my computer isnt detecting it and it doesnt seem like its in the slot all the way.
Make sure the video card back-pane is not caught on the slot openings towards the bottom, and that the back lock on the PCIe slot is free before you try to install it. If you can't figure it out, have someone else look at it before you damage the card or motherboard with too much force or pushing it wrong and scraping connections.
