Gtx 960 power requirements
Knightrot
Even though Nvidia has told that 400watt psu is enough for gtx 960 do you think that cooler master thunder 450watt is capable of delivering the juice to oc edition as well as the standard edition as I'm low on budget
A GeForce GTX 960 needs 20 amps on the 12v+ rail and a 450 watt power supply with 1 - 6 pin PCIE power conection.
Your Cooler Master meets the requirements , enjoy the new card. 😀
The power consumption between a stock GPU and a factory OC'd one will not use any significant amount of power. You should be fine with the recommended wattage. It should be able to handle an OC even a little higher than the factory OC.
