R ravenlynx Honorable Jan 10, 2014 30 0 10,530 May 10, 2015 #1 hello i have a very bad concepts about sli and crossfire i have gtx 960 and i was wondering that if i get a gtx 970 will i be bale to run them together if i can i wall buy one in 2 or 3 months thanks in advance
Solution F F furiousss May 10, 2015 no you cant sli a gtx 960 and gtx 970 together. you need both the gpu of same model. get another gtx 960 and sli it.
F furiousss Reputable Jul 9, 2014 129 0 4,710 May 10, 2015 Solution #2 no you cant sli a gtx 960 and gtx 970 together. you need both the gpu of same model. get another gtx 960 and sli it. Upvote 0 Downvote Solution
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 May 10, 2015 #3 And it'll work better if they are both 4gb models. Then you can run 1440p monitors and run high end games at high settings. Upvote 0 Downvote
