Question GTX 970 Fan speed on idle
ampalaea4
Commendable
Feb 27, 2019
6
View: https://i.imgur.com/FqPBS8k.png
Hello all. Is it normal that my fan speed at my Nvidia 970 is too high on idle? About 2 years ago I did noticed a loud noice from card and figured out that only 1 fan was working... the other one was not moving. But now it does not make that loud and my pc is in position that would be a lot of trouble to open it and check 🙁. Is there a way to check if both fans are working from a software?
Thanks in advance!
Actually this happened to me a while ago:
View: https://www.youtube.com/watch?v=zcTPwzJRCao
but was ok after a while...
Thabks for answering. I did open the case after all and checked that both fans are working. I am now doing a quick format and then i will check out with the programs you said!
