GTX 970 G1 Very Low FPS!
Aylon
Hi,
I have a problem from the last update.
Im playing CS:GO with this PC for the last 2 years.
On the same settings like allways play I get 250-300 FPS, But after the update I get 80-120.
I try to reinstall the update, install an older update even I format my PC nothig has change!
My CS:GO video settings:
Resolution: 1280x1024 4:3 strech
Everyting low
Vsyns: off
My PC:
I7 2700k
16gb
GTX 970 G1
Motherboard: gigabyte z68a-d3h-b3
OS: WINDOWS 10 PRO 64BIT
Everything is update to the latest update!
Please help me!
I don't play counterstrike, but I would recommend trying to change some of your original settings back because I know that in the majority of the games I play, every time there seems to be an update, the settings change back to defaults.
