GTX 970 needs 6-pin and 8-pin. PSU has only two 6-pins
Can you provide a link for one so I can be clear? Is there a difference between an adapter and a lead converter?
yeah try here http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X6+to+8+pin+lead+pcie.TRS0&_nkw=6+to+8+pin+lead+pcie&_sacat=0
My PSU has 500W and I have the same problem. I have the gtx 970 Gigabyte G1 .
Should I buy an adapter? Aren't adapter's harmful?
Or Can I put the 6-pin inside the 8pin slot. Would that work and is this harmful?
