GTX 970 PC Power Requirements
Joaodestroyer
23
Wait that's not what I meant. I was asking what power supply I should get for my PC. The PSU you linked me is funny enough the one I was looking to buy today but I wasn't sure. So do you think that I should get the Corsair power supply? I am also planning on getting a Gtx 970 of this model: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121899&cm_re=gtx_970-_-14-121-899-_-Product Can you recommend me any Gtx 970s? I don't want to overclock anything; I just want a 970 that will do the job and be good quality too. Thank you for your help!
Yeah, the PSU I linked you would do the job. As far as a particular brand of 970s, if you won't be overclocking then if one brand is significantly cheaper than another, go for the cheaper option.
My choice would be the EVGA: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487088&cm_re=970-_-14-487-088-_-Product
So what is the difference between the card you sent me by that link and this card? http://www.newegg.com/Product/Product.aspx?Item=N82E16814487076&cm_re=gtx_970-_-14-487-076-_-Product
The only difference between the two is a slightly higher factory overclock on my card - you said you didn't want to do any overclocking so my card would provide a small bump in performance over the card you linked. Whether that bump is worth $10 is up to you, considering it'd probably be a pretty small increase.
