D Drytanman Reputable Apr 12, 2015 29 0 4,530 Apr 12, 2015 #1 On my gtx 970 I have had it for 5 months now and I notice on the side of it had a orange and black type of stain is this normal or bad?
Solution Phillip Corcoran Apr 13, 2015 It's normal - caused by the flux used in the soldering process, As the card heats up in use, the flux causes the staining.
Phillip Corcoran Titan Moderator Sep 7, 2013 25,977 860 120,140 Apr 13, 2015 Solution #2 It's normal - caused by the flux used in the soldering process, As the card heats up in use, the flux causes the staining. Upvote 0 Downvote Solution
