GTX 970 weird noise when playing ay game (not the fans)
Neeedles
So my MSI GTX 970 Gaming 4G started making this clicking noise whenever i play any game. Righ when any game loads and i start playing the noise begins. The noise is exactly the same as this one ? https://www.youtube.com/watch?v=Ks3jAJ1VlLQ
No, it's not the fans, stopped all fans in the PC and the noise persisted. I'm also 100% sure it's the GPU.
Update: So it's probably coil whine coz it's exactly the same as in this video https://www.youtube.com/watch?v=ffVqmYdfCCc
Could be a coil whine or something else, make sure your covered by your warranty, and contact MSI and they might suggest a replacement or it could just be a simple coil whine, which won't do any harm, just make an annoying noise.
Hope this helps!
Do you know if coil whine is ever bad for a GPU's health?
Nope, not in the slightest. Its very common. Some cards can make more noise than others.
Enabling Vsync can help, as it often happens under very high load. Also running a video benchmark program for a few hours can help.
OK, thanks I am having that with my STRIX 970 on stratergy games. Glad it does no damage :)
Thanks for your help!
No problem.
Some people have tryed running Unigine Valley for about 3-4hours and it has fixed it or made it quieter.
OK, I actully have that installed I will give it a try if it becomes louder or more common.
Thanks again!
