GTX 970M able to run 27 inch external monitor?
Alex_185
Commendable
Mar 27, 2016
Hey fellas, i have been thinking getting a external 27'' IPS screen to replace my laptop screen as the monitor.My laptop is a MSI GS70 Stealth Pro: https://us.msi.com/Notebook/GS70-Stealth-Pro-GTX-970M#hero-overview with a GTX 970M video card.
My question is: should i buy a 2k resolution or 1080p if my main purpose is to play video game like World of Warcraft and watch movie occasionally. I have been search for monitors and found the following ones appealing to me, i appreciate if you can gime some suggestions. My budget is $150-$300
AOC 2757fh IPS 1080p: http://us.aoc.com/products/details.php?27-ips-led-monitor&id=49
ASUS MX279H IPS 1080p: https://www.asus.com/us/Monitors/MX279H/
No sure if i should consider QNIX 2710 which has a 2K resolution with a cheap price. Not sure if it has power adapter issue since it is a Korean monitor.
If you think 2K resolution is a better option, could you recommend me some options with reasonable price even if it exceed my budget a little bit.
Go 2k for sure. 1080P at 27 inch is too big for that resolution, if you have good eyes, there won't be that crispness you'll find with 2k.
