Gtx 980 2-way SLi 3 monitor
johnayyboyy
24
I haven't gotten my third monitor in yet, but i have received the second.
But, its seems to not want to work.
Ive plugged my primary Hdmi into the second monitor and everything works fine.
Im thinking its the cord.
Its an Hdmi to Display port cord.
Which Cords would you guys recommend.
The monitors are, AOC e2752vh.
thanks
As the other guy said, try a different cable to confirm your suspicions. Also, at 1080p 60Hz, DVI is just as good as HDMI. HDMI is also capable of conveying sound signals, but you won't need it if you game with heaphones or if you don't use the monitor's built-in speakers.
If it still doesn't work, make sure you applied the proper settings to your PC so as to use the second monitor.
