Cross posting this from a reddit post that's just getting zero attention.
Computer Type: Desktop, custom build.
GPU: GTX 980, 4GB VRAM, no overclock
CPU: Interl i7 6700k 4ghz
Motherboard: Gigabyte ATX DDR4 Intel LGA 1151 SATA E (6Gbit/s) Motherboards (GA-Z170X-Gaming 7.) Can't seem to find the BIOS version, but it was whatever came on there, never updated/flashed/whatever.
RAM: 16GB, I think corsair.
PSU: Cooler Master Silent Pro M - 1000W, 12v rail, not sure about the output, kinda confused by all this.
Operating System & Version: Windows 10 build 16299, upgraded from 7.
GPU Drivers: 388.43
Description of Problem: Provide as much info about the issue as you possibly can, images and videos can be provided as well.
Troubleshooting: About a week ago I noticed my 980's fan was kicking in while idling, which I thought was strange, since it doesn't normally do that unless my room temp is hot. It appears my card was drawing 25% and heating up to around 60C. I went through a lengthy process of trying to figure this, which included:
Removing Precision and Afterburner
Completely reinstalling GPU drivers (from the latest version.) -Turning hardware acceleration off in anything that uses it
Examining Process Viewer and task manager to see if anything stood out as strange (nothing did)
Running a malware scan (nothing found)
Running CCleaner.
If I start my computer up from a full shutdown it will draw about 8% power while idling for some time, usually around an hour or so, then at some point it just jumps up to 25% usage and holds there, even if I shut every program I can find down.
The programs I would usually run at any given point in time are Firefox or Opera, Discord, and Steam. Again, with all of those off, the GPU in GPU-Z will show a 25% draw and 60C idle temps which seems abnormal to me. I'm not sure where else to look or what could be going on and I worry about this possibly damaging the card in the long run.
The only major change I can think that I made recently was installing a Huion drawing tablet, but it's not plugged in and I'm not actively running any of its software as far as I can tell.
http://gpuz.techpowerup.com/18/04/07/n4v.png
The last thing I tried was downgrading my driver to 388, which I believe is the factory default. For a while this worked, I was idling at 8-11% usage which was fine, with temps between 30-40C. The higher end of that is likely due to ambient temperature in my home. However, after returning to my room an hour later, the CPU was hanging at 25% again, 60C, with nothing running. I used Invidia Inspector and set up the "Multi Display Power Saver" option as instructed in a thread elsewhere for a similar issue. So far that seems to be keeping it down, and I read it should still draw more power when it's needed, but I don't want to say the issue is totally resolved just yet.
I'm wondering what might cause this and if there's something I should be doing to prevent it in the future. Is it normal for this card to behave this way, is using the "Multi Display Power Saver" option a good fix, or should I be looking into something else?
GPU Drivers: 388.43
Running CCleaner.
