Hi So i bought MSI Gtx 980 4gb and i was so happy when it arrived the problem was i didn't had any two 8 pin connectors from GPU to PSU , I was in town next day looking in every shop computer and phone shop asking for connectors or similar pins , no luck was in electric repair shops asked if they can give me some similar pins no luck
So i was thinking can i use Standard wire don't know what voltage it supports but i bought it from ebay(china)
1.Cut wires
2.Stripped and taped wires
3.Used some Female connectors from fans
4.Shrink tape/wrap
The problem is No one has ever done this and i only found one forum so , im afraid to even test it ! http://www.rage3d.com/board/showthread.php?t=33928077
So Im Using Seasonic PSU and Z97 S55 Mobo
http://postimg.org/image/v01687zoj/
http://postimg.org/image/6vbp9xop7/
http://postimg.org/image/ot4r8ahj3/
http://postimg.org/image/aml9w92dn/
http://postimg.org/image/5d0bd4n39/
GTX 980 came with 6 to 8 pin extension so im taking that as my guide but not sure if im wireing right :/ !
Anyone Know or done something like this ?
1.Cut wires
4.Shrink tape/wrap
