Hi,
Basically one day came from work and turned my PC on and there was no signal from my GTX 980. I can't even enter BIOS because I do only see that "there's no signal".
Fan is spinning on the GTX 980 and LED lights up the logo.
!!! Using my old GTX 760 works fine, it receives the signal !!!
So far what I've tried:
1. Reinstalled GPU and checked that all pins are properly connected.
2. Tried to use Display Port(gpu)-HDMI(lcd) / HDMI-HDMI cables. Have NOT tried with DVI.
3. Turned on the PC w/o power pins for GPU - same result as with power pins connected (fan is spinning led lights up the logo).
4. Used my second PCI port.
5. Tried to reset CMOS .
6. Using old GTX 760 all other stuff like uninstalling video drivers using DDU etc etc.
Some specs/info:
1. PSU: Corsair CX600 (600W) - connected to GPU using 2x 6-pins and 2x 2-pins (which is 2x 8-pins as requires GPU)
2. Around a week ago updated BIOS (mobo: MSI B75-G43)
I have installed and played a game called PUBG the night before it all happened ( if that makes any sense
Any more suggestions?
Some specs/info:
