Hello everyone,
I would just like to ask a question about my new PC, I am somewhat familiar with hardware ext but please bear with me if I don’t make too much sense.
I have a ASUS GeForce GTX 980 Ti STRIX OC 6GB GDDR5
I have been looking at several forums and am now totally confused with what the temperature should be with this graphics card under load.
I tested several games with max settings including, Civ 5, Mordhiem, Metro 2033 redeux and star citizen, all of which give me a max load temperature between 83 and 84 degrees with a fan speed at 58% (going by afterburner).
Now from what I understand when the card reaches this temperature it starts to throttle.
However with 84 degrees under load, I can get it down to 76 degrees if the fan is at 80% speedish (but pc sounds like it’s a helicopter), and I can also get the temperature down to 79 – 80 degrees with the side off.
My questions are:-
1) Is my gfx card ok at 84 degrees?
2) Is it possible that the gfx are being throttled?
3) Should I increase the fan speed through afterburner if this is a problem?
Many thanks for any help!
Loccen
My questions are:-
Loccen
