GTX 980 Ti texture issue! (HELP)
LaurX
39
Hello, dear boys and girls!
So I wan't ask you, maybe someone knows why my textures are blurry at distance in all games?
For example, I play PUBG and my textures in distance are some kind of blurry, you can't actually see nothing because of the blurry textures.
When I play on my second PC, it's all fine. Second PC has GTX 1060
I am using HDMI cable not a display port cable, could it be related to that?
My build:
  • CPU: i7-7700k liquid cooled with waterblock @ 4.20 Ghz
    GPU: GTX 980 Ti liquid cooled with waterblock
    RAM: 16 GB Corsair 3200 Mhz
    MOBO: ASUS MAXIMUS IX FORMULA Z270
    PSU: Corsair AX 760
    SSD: SAMSUNG EVO 500 GB
    OS: Windows 10 Home 64-bit
Thank you, any help will be appreciated!
Yes they look different, did you check the game settings and compare them? AF is a quality setting in games that affects texture quality. Anisotropic Filtering.
In-game settings are the same. I put AF on 16x and still not as good as my GTX 1060...
